fuel injector leak?
pearl4door
fuel injector leak?
ok all i finally fixed the manifold revving problem, the gasket wasnt sealing all the way so now i have another problem. when i turn the car to the 3rd click to let the fuel get back into the system and build pressure it starts to leak, if you are standing at the front of the car it is the injector on the far left side (passenger side) and i have tried everything, now a honda tech friend tells me that i should just buy these little kits that replace all the o-rings on the injectors themselves for $7 a piece, is there anything that i can do because i feel that the injector is leaking from the top where it meets the fuel rail. any suggestions or ideas?
fuel injector leak?
ur o ring is pinched, or just broked! change it............
fuel injector leak?
The o ring is at the top, I have some old used ones for free if you want to pick them up.
EDIT: Just saw where you were from, just PM me your address and I will ship them to you.
