TPS sensor
hondaman
TPS sensor
Post by hondaman »
I just replaced the TPS sensor (Bought 2/one from Andy JT and the other from Stephanie) on my factory throttle body in my '99 Civic SI, because the light had been staying on. The code was a very high number which the dealer told me the voltage was not correct for the TPS. I reset the ECU by unplugging the TPS and negative battery cable and waited 5 mins. before putting both on. Adjusted TPS position for smooth idle, but light still came back on, on 3 different tries. I am out of my mind trying to figure out why the check engine light keeps popping back on. All plugs are correctly hooked to the proper location, both TPS and MAP sensor. All 3 sensors can't be bad. Any suggestions?
TPS sensor
did you calibrate the new TPS?
TPS sensor
Post by Gunmetal Si »
btlfedgolf;106236 wrote:did you calibrate the new TPS?
yes uu need to get it positioned right to get the correct voltage
:yarr:
deetz
TPS sensor
Post by deetz »
:werd: this needs to be done..
~chris~
-scca setup 99 grand am gt
-85 cj7
TPS sensor
Post by mike93hatch »
you dont adjust the TPS by listening at how well it idles lol. you use a multimeter and tap the wires.
there isnt much to sensors and check engine lights.
TPS ----> wiring ----> ECU
if you replaced the tps with a known good working one and youre still getting a CEL for the tps then its either the wiring or the ecu. there's nothing else it could be.
hondaman
TPS sensor
Post by hondaman »
Please LMK what the correct voltage should be for my application. I don't have a multi/voltmeter. I thought it was 4 volts, but I'm not sure. My code is P1122. TPS sensor higher than expected. Thanks
big pipe
TPS sensor
Post by big pipe »
im pretty sure it ranges from 0volts (shut) to 5 volts(wide open)
this space for rent
TPS sensor
hondaman;106330 wrote:Please LMK what the correct voltage should be for my application. I don't have a multi/voltmeter. I thought it was 4 volts, but I'm not sure. My code is P1122. TPS sensor higher than expected. Thanks
whats the CEL code? (when counting flashes)
tap 2 of the three wires on the tps, forget which colors they are but youll need to tap the + to + lead on the multimeter and negative to negative.
fully close 0.5V
WOT 4.5V
TPS sensor
Post by rickles8099 »
