Aebs intake manifold installation?
pearl4door
Post by pearl4door »
ok guys i bought an aebs manifold from phate a few weeks back and i am finally gettin around to installin it along with an aem fuel rail, the problems are that on the manifold i am relocating the hoses but there are 3 bigs holes and 4 tiny holes, i found a hose for 1 of the 4 tiny holes and 2 hoses for the other 3 bigger ones and i just want to know what all hoses should go on this. please dont knock me for buyin this manifold because i might try other ones just to see which i like best
fuel rail is the problem of on the fuel line from the filter it has a ring around it with a hole from the hose and on the stock fuel rail it has a hole through the thread so fuel can be distributed but on the new rail the thread is just solid so what do i do?
the aebs is a good manifold .. dont sweat it .. same one myself and spork are using , do what i did on my aebs, just use vacume caps and cap off the ones you dont need you should only need 2 or three of them the rest are for extra things like, boost gauges and turbo related items.
as far as the fuel line it should work just like oem .. never ran into that problem before and i have used aem rails also
pearl4door
ok thanks for the tip about the manifold cause i was kinda confused but now the fuel rail is really confusin me cause i figured it would be a direct swap to but apparently i gotta do a little reading and thinking cause the bolt where the fuel comes from the fuel filter is solid and wouldn allow any flow through the rail. ill post some pics up tonight hopefully and maybe that can give you an idea of what im experiencing exactly
