anyone know how to do an ITB setup on a B18A1 motor?
justme5424
Just seeing if it would be easier to an ITB setup than Turboing it? If it's easier and cheaper, then I think I'll go that route if anyone can help? or would it be best if I just built and turbo'd the motor? thanks in advanced guys?
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
Digital Sol
this question lacks alot of informationjustme5424;98114 wrote:Just seeing if it would be easier to an ITB setup than Turboing it? If it's easier and cheaper, then I think I'll go that route if anyone can help? or would it be best if I just built and turbo'd the motor? thanks in advanced guys?
itb's are going to be a waste of time/money without the right supporting mods......there basically a last to do mod after your motor is built for na, im talking about bottom end, head, high comp, stage 3 cams etc'
$1200 itb's on a stock motor are not going to yield much gain, nor be that suitable for a daily driver'
my .2cents, build the bottom end & boost it'
also with boost you dont always have to build the motor to make some decent power, depending on the millage and condition of your motor right now you could assemble a full turbo kit with all part and have it tuned for probley under 1k.justme5424;98114 wrote:Just seeing if it would be easier to an ITB setup than Turboing it? If it's easier and cheaper, then I think I'll go that route if anyone can help? or would it be best if I just built and turbo'd the motor? thanks in advanced guys?
where itbs done right will cost you around 1k just in parts no tuning and no supporting motor mods.
itbs are designed for high comp high reving motors, your ls unless you do a ls/vtec set up will never be that reliably
02Type-S
You can use some from a CBR and retro-fit them. Thats pretty a common way on Honda motors. You will need to tune it with some type of engine management tho (E-Manage, NEO, possibly Hondata)
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
you are overlooking the fact that it would be COMPLETELY RETARDED to put ITBs on a stock b18a/b. and for the same price as boosting the car (once you consider the price of welding and adapting the cbr itbs and tuning) you will see no real gains with ITBs compared to the 100+ horsepower from boosting.02Type-S;98172 wrote:You can use some from a CBR and retro-fit them. Thats pretty a common way on Honda motors. You will need to tune it with some type of engine management tho (E-Manage, NEO, possibly Hondata)
then you factor in our climate, and I would bet that boosting would run MORE reliably than itbs around here.
big pipe
you would get more power out of a skunk 2 manifold, and a oversized single throttle body
this space for rent
Digital Sol
big pipe;98177 wrote:you would get more power out of a skunk 2 manifold, and a oversized single throttle body
yea and on a stock b18 motor that"ll be good for 5whp
boost it and call it a day, want to feel better about it? Do some better pistons/rods then boost it and call it a day'.
02Type-S
And you are overlooking the fact that all I did was answer the question he posted in his title. Did I say it would be reliable, or give him a bunch or horsepower? No. I know it wont, I'm not an idiot. Of course boost is better, you really can't compare the two. Especially while working with a B18.Spork;98173 wrote:you are overlooking the fact that it would be COMPLETELY RETARDED to put ITBs on a stock b18a/b. and for the same price as boosting the car (once you consider the price of welding and adapting the cbr itbs and tuning) you will see no real gains with ITBs compared to the 100+ horsepower from boosting.
2002 Acura TL-S
2002 Acura TL-S
heh... i quoted you as a way to jump in and add my .02 to the mix... no hard feelings02Type-S;98335 wrote:And you are overlooking the fact that all I did was answer the question he posted in his title. Did I say it would be reliable, or give him a bunch or horsepower? No. I know it wont, I'm not an idiot. Of course boost is better, you really can't compare the two. Especially while working with a B18.
02Type-S
gotcha, none takenSpork;98336 wrote:heh... i quoted you as a way to jump in and add my .02 to the mix... no hard feelings
2002 Acura TL-S
2002 Acura TL-S
