which manifold would you pick
big pipe
Post by big pipe »
im torn. this is the only real decision left for "how to spend my tax refund in 20 minutes"
which manifold should i get for the accord?
im thinking i might get a little faster spool with the cast log (exhibit A), and it would probably last a little longer.
or go with the stainless semi-tubular (exhibit B) for a little better performance on and off boost, possibly a better wastegate placement also.
ive got it narrowed down to these 2. and dont say they both suck, get a equal length top mount, because nobody makes one for the f22b2, and its only gonna rev to about 6500ish rpm
.........................A..........................B
You do not have the required permissions to view the files attached to this post.
this space for rent
Post by 5thgen »
inline pro manifold is about the best out there for a cast manifold.
they work very well.
Post by mike93hatch »
B without a doubt because the wastegate placement sucks bad on A liike you said.
big pipe
Post by big pipe »
mike93hatch;97458 wrote:B without a doubt because the wastegate placement sucks bad on A liike you said.
thats pretty much what i was thinking too, also it puts the turbo a little farther away from my p/s-a/c (bigger downpipe)
this space for rent
