b18a boost
Mesh_Teg
b18a boost
Post by Mesh_Teg »
offhand can any tell my how much boost a stock b18a1 can handle
b18a boost
Post by rickles8099 »
30psi
big pipe
b18a boost
Post by big pipe »
stock, its not boosted
j/k maybe 8 psi depending on the tune, untuned the first time it spools itll blow
this space for rent
Mesh_Teg
b18a boost
Post by Mesh_Teg »
ok thanks
b18a boost
you do realize on what kind of turbo and what kind of fuel management it is being ran on that will determine the amount of boost it can run.
the better question would be, how much horsepower can a stock b18a run reliably with a t3 .60 trim and crome.
then an more precise answer would be, about 300whp. anything more can blow the rods.
Mesh_Teg
b18a boost
Post by Mesh_Teg »
thank you very much
b18a boost
Post by 5thgen »
mine (b18b1/sc34) is at 17psi at the moment.
b18a boost
Post by HardCore97 »
stock bottom end?
b18a boost
Post by 5thgen »
everything is stock beside head studs.
b18a boost
nice. ever dyno it?
