compression test
compression test
Post by rickles8099 »
would doing a compression check when an engine doesnt have an intake manifold or exhaust manifold on hurt the engine and/or have an effect on the readings one would find?
compression test
I dont think it would huurt it at all. The valves are what is regulating the pressure in the cyl. Just make sure the car is not going to try and kick over and run on 3 cyl.
EDIT: i am an idiot.....no IM means no injectors, so it wont try to start.
twkdcd595
compression test
Post by twkdcd595 »
no, compression check will still work with no intake/ exhaust manifolds.
ludeboy
compression test
Post by ludeboy »
twkdcd595;95411 wrote:no, compression check will still work with no intake/ exhaust manifolds.
Correct, and it won't cause any damage.
compression test
Post by mike93hatch »
all correct except for the engine starting lol
deetz
compression test
Post by deetz »
mike93hatch;96874 wrote:all correct except for the engine starting lol
it should work:bananahump:
~chris~
-scca setup 99 grand am gt
-85 cj7
compression test
I corrected myself
compression test
Post by 5thgen »
will probably get a little bit different results from not being warmed up.
