o2 sensor wiring question
tommygun89hb
Post by tommygun89hb »
if you wire an o2 wrong will it cause the engine to run a smooth
high idle ???
g3integragsr
Post by g3integragsr »
I do not believe an O2 sensor has anything to do with the idle
tommygun89hb
if i wired it wrong then i would get a check engine light right
the reason i ask is because i wired in a a/f gauge and it stays rich at idle unless i down shift and let off the clutch when im driving
Silver Knight
Post by Silver Knight »
yes it can throw a code
DC5
tommygun89hb
i finally fixed it i fixed the fast idle valve the plastic white screw needed to be ajusted thanks and close thread
ObsesionWitSped
Post by ObsesionWitSped »
What happened with the O2 sensor?
Talking about Andy's drop:
tommygun89hb
nothing it was the fast idle valve i just thought that it could be the o2 i have herd stories of if they wire it wrong then it will run rich like my a/f gauge
ObsesionWitSped
Ok. Got 'cha.
tommygun89hb
thanks for everybodys help i found a really good write up on the net but didnt know how everyone on this site would react to linking something from honda-tec on this site(isnt there some kind of rule that your not suposed to do that on here)
ObsesionWitSped
tommygun89hb;90671 wrote:thanks for everybodys help i found a really good write up on the net but didnt know how everyone on this site would react to linking something from honda-tec on this site(isnt there some kind of rule that your not suposed to do that on here)
Post that bish! Alot of arguements here end up/involve links/quotes from Honda-Tech and other sites.
