yeah man, ive been reading alot about runnin K pistons, the only problem is the bore. i would have to go f23 block. i really want to do the H crank and rods. from what ive read that 95mm stroke wont last a season spinning past 7K. if i punch out the f23 block 1mm with the H internals itll basically be an iron sleeved h22 (with a f head) H crank is forged, the F crank is not. im also thinkin a6 head/IM for the said reasons, also i could piece it all together with the car still runnin on the stock engine..........either way its still in the early stages, nothing set in stone yet..........i did find a f23 bottom end for 100 bucks and the 55mm h22 crank for 50.
with the H crank and rods, and a 87mm bore i could probably just use off the shelf h22 pistons too, but then i would have to machine the combustion chambers 2mm to match the block. the F head has a slighly smaller cc which would raise the compression about .3-.5 over what the pistons claim
ill figure this all eventually, and keep yall updated
btw the end goal is to have a bulletproof bottom end thatll go to 7500-7800
boost is gonna come next winter, thats a whole nother thread
