headgasket???
HondaChild
headgasket???
Okay so when I got home from school I tried to start the car for the hell of it and it started no problem. Could it have something to do with not being touched for a prolonged period of time? But I will shut it off and restart it and update you people.
Know your roots.
HondaChild
headgasket???
okay shut the car off and restarted it once warm and it stared fine but when given more than 1/2 throttle it bogs and misfires.
Know your roots.
headgasket???
check the tps sensor, map sensor, and connections going to the tps and map.HondaChild;84773 wrote:okay shut the car off and restarted it once warm and it stared fine but when given more than 1/2 throttle it bogs and misfires.
deetz
headgasket???
i said the tps wayy back in the beginning.. noone checked it
~chris~
-scca setup 99 grand am gt
-85 cj7
-85 cj7
HondaChild
headgasket???
OKay will do. and I just found out that my gas cap was loose would that effect it at all? usaully that would send a CEL though.rickles8099;84807 wrote:check the tps sensor, map sensor, and connections going to the tps and map.
Know your roots.
andyjt
headgasket???
Did you ever check into the resistance of the ignition coil?HondaChild;84834 wrote:OKay will do. and I just found out that my gas cap was loose would that effect it at all? usaully that would send a CEL though.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
HondaChild
headgasket???
I don't know how to test that. And steve came over to help with the car and we got it started 4 times 1 time ran fine, 2 and 3 times bogged at start but idled fine, 4 time ran a little rough but gave it 1/4 throttle and it almost died and shot smoke out the TB. timing is fine, but the spark plugs are black (looks like carbon buildup).andyjt;84839 wrote:Did you ever check into the resistance of the ignition coil?
A check engine light finally came on, so I need to get it read.
There was also a horrible hesitation...basically, if you flick the t/b open the motor doesn't rev right away like it should, it lags for a second.
Know your roots.
headgasket???
HondaChild;84659 wrote:
yeah sure let me push my car down to springfeild.:PDT_repa:
i dont live in springfield ??????
i live in holts summit, about 2 miles north of the capitol of missouri. for the people that dont know, that is jefferson city
HondaChild
headgasket???
OKay sorry I did not know that you lived in holts summit. And if you would not like to contribute to helping me with my problem then please keep opions out of this thread. Thank you very much.mike93hatch;84887 wrote:i dont live in springfield ??????
Know your roots.
