Yes I'm sure that I am getting spark but I will double check since I used an extra spark plug I had laying around so I will try it with the plugs that are actually in the car. and I am also 98% sure that I have the firing order correct as I marked the dizzy when I put the MSD dizzy on the car.Spork;84349 wrote:This:
is NOT true. are you 100% sure that you get spark in the cylinders?
and have you double checked the firing order on the dizzy?
honda firing order (I know for b-series, and it should be the same for d-series),if you are looking at it from straight on, should be like this:
dizzy:
3 4
1 2
Motor:
4 3 2 1
headgasket???
HondaChild
headgasket???
Know your roots.
HondaChild
headgasket???
Okay well the cylinders werent flooded so that is out of the question. would a bad IACV cause it not to start????? come on I need more ideas!
Know your roots.
civicex442
headgasket???
did you do this yet?SilverStreak;84262 wrote:PUT YOUR OEM CAP, ROTOR, COIL AND WIRES BACK ON THE CAR!!!
98 EJ6
03 WRX
HondaChild
headgasket???
no and it would be rather since I have a MODIFIED distributor to eliminate the internal coil. and if you read I have spark going to the spark plugs.civicex442;84401 wrote:did you do this yet?
Know your roots.
headgasket???
its like the blind leading the blind in here..
headgasket???
3 blind mice 3 blind mince.. see how they havent a clue as whats gong on ......mike93hatch;84467 wrote:its like the blind leading the blind in here..
HondaChild
headgasket???
It started and ran fine. Lets hope it stays that way.
Know your roots.
HondaChild
headgasket???
okay so once I shut the car off and it cooled down I went to start it back up to test drive it, it would not start again. It is doing the same thing as before.
Know your roots.
headgasket???
what did you do to get it to start?
HondaChild
headgasket???
I took the plugs out turned the motor over a few times. left them out while I was at work(2 hours) then put them back in and it started right up.Spork;84501 wrote:what did you do to get it to start?
Ig to it to start again and this time I got video of it running. It does not seem like it is running on all 4 cylinders. What would cause this? and the plugs are black. I will have the video up in a minute.
Know your roots.
