headgasket???
tommygun89hb
headgasket???
mine was a little warm but it wasnt super hot at all it was warmer than the intake or the header
headgasket???
PUT YOUR OEM CAP, ROTOR, COIL AND WIRES BACK ON THE CAR!!! MSD=JUNK!
Who told you not to put those on your car...
HondaChild
headgasket???
okay well maybe its normal just never noticed. I reassembled the dizzy after taking the cap and rotor off the car will not start now. it attemps to but does not succeed.tommygun89hb;84261 wrote:mine was a little warm but it wasnt super hot at all it was warmer than the intake or the header
Know your roots.
HondaChild
headgasket???
OKay so I am getting spark, getting fuel, and the compression was 150 psi in 3 cylinders and 145psi in #3. Dont know if those compression numbers are good or not. and my spark plugs are covered in oil and gas.
Know your roots.
tommygun89hb
headgasket???
your valve cover gasket set def needs to be replace for sure
and the readings for you compression are good
not to big of a diffrence in the one cylinder so its all good
HondaChild
headgasket???
okay cool but it still wont start. and I have no idea why.tommygun89hb;84295 wrote:your valve cover gasket set def needs to be replace for sure
Know your roots.
tommygun89hb
headgasket???
did you get it started justin
HondaChild
headgasket???
nope still no luck the motor cranks over just fine but no start.tommygun89hb;84333 wrote:did you get it started justin
Know your roots.
headgasket???
This:
This:
Suggests that this:
and have you double checked the firing order on the dizzy?
honda firing order (I know for b-series, and it should be the same for d-series),if you are looking at it from straight on, should be like this:
dizzy:
3 4
1 2
Motor:
4 3 2 1
+HondaChild;84263 wrote:I reassembled the dizzy after taking the cap and rotor off the car will not start now.
This:
HondaChild;84288 wrote:my spark plugs are covered in oil and gas.
Suggests that this:
is NOT true. are you 100% sure that you get spark in the cylinders?HondaChild;84288 wrote:OKay so I am getting spark
dizzy:
3 4
1 2
Motor:
4 3 2 1
