what do you think?
what do you think?
ARP rod bolts too
what do you think?
Post by HardCore97 »
is that all?
Drowzysleeper
what do you think?
Post by Drowzysleeper »
i was hoping for low 15's in my eg hatch with my almost fully built ls. and you weigh more than my hatch. i have the ls tranny though.
IM AN EPIC FAIL
what do you think?
Post by bildo16 »
HardCore97;84769 wrote:im looking for a vtec head right now to see if i can find one with a messed up valvetrain or something so i can throw in a type r valvetrain.
most of the time when something interanlly goes wrong in the head, the head is junk. you can pick up a complete head for a few hundred bucks. search hard and youll find great things.
what do you think?
ok thanks man
virginEF
what do you think?
Post by virginEF »
Caution I'm new to hondas: Is the compresion the same between B18b & B18c, I dont think so. If your planning on Vtec later then why not save and go B18c?
what do you think?
Post by bildo16 »
virginEF;85745 wrote:Caution Noob: Is the compresion the same between B18b & B18c, I dont think so. If your planning on Vtech later then why not save and go B18c?
OH NOES!!!!!!!! B18+Boost=Fun.
what do you think?
virginEF;85745 wrote:Caution I'm new to hondas: Is the compresion the same between B18b & B18c, I dont think so. If your planning on Vtec later then why not save and go B18c?
compression is only one factor, another difference in the LS block vs. the GSR block is the stroke; LS is 89mm and the GSR is 87.2mm, this means that an LS vtec motor will produce more torque than a gsr. the lower compression also makes the LS motors very good for boost (as Bill just stated above me). and a third perk is that LS blocks are the closest thing to 'dime-a-dozen' that you can get with b-series, so if you mess one up, you can buy a new one for a few hundred bucks (max.) and you are on your way again.
virginEF
what do you think?
Post by virginEF »
Ahhhhh, thanks for clearing that up!
what do you think?
Post by 5thgen »
if you build either motor (gsr/lsvtec)....lsvtec will come out cheaper at the end anyway.
