LS/VTEC Turbo vs CR/VTEC Turbo
Post by RyanA »
Also, if you are planning on doing a stock block without aftermarket sleeves, I'd stick with the LS. B20's with boost seem to be running on borrowed time.
If you are sleeving, another reason to use the LS block is because a lot of sleevers will not guarantee the water and oil not mixing on the B20 block after it's sleeved.
Another option is to be a dick (like me?) and sleeve a B16 block, get the B16 stroker crank and make an engine that most people will ASSume it's "just a B16"
RyanA;82092 wrote: Another option is to be a dick (like me?) and sleeve a B16 block, get the B16 stroker crank and make an engine that most people will ASSume it's "just a B16"
i've thought about that... but with the shorter deck height, I'd still choose to do an LS or GSR block... a bored and stroked 2.26L LS block is still just an LSVtec
:popcorn:
.:si:.
Post by .:si:. »
RyanA;82092 wrote:Also, if you are planning on doing a stock block without aftermarket sleeves, I'd stick with the LS. B20's with boost seem to be running on borrowed time.
ya there is that too....i would like to build a b16 and have a really strong b16.
:vtec228: blake:vtec228:
00 CiViC Si
95 Integra LS
~-*Broadway Glass*-~
:evil1:3146384545:evil1:
All Your Autoglass Needs
PM me for a price on any glass
