injector question
tyler7
injector question
Post by tyler7 »
I got a quick question.Im running very lean and i dont have the money to buy k-pro to tune my motor, so can i get bigger injectors, like type-s ones and run ok or with out a tune will it just run like crap. i think my stock injectors are 240"s or 260's and the type-s ones are 315's. Thanks Tyler.
injector question
Wait to get K-Pro. You can't just throw in bigger injectors and expect your car to run right.
tyler7
injector question
Post by tyler7 »
thanks for the response. i didnt think that it would work but i had to find out for sure.
injector question
not sure how the k's regulate the fuel pressure but you could always just upgrade to a adjustable one with a a gauge and bump up the fuel pressure a cpl pounds to help compensate.
tyler7
injector question
Post by tyler7 »
hummm. thats a good idea, should i just get a new fuel rail and then put a regulator on that or can i keep my stock rail and put a regulator on it.
injector question
stock rail just add the regulator
Its Pat!
injector question
Post by Its Pat! »
you should just bore them out... you get better flow that way :D
spray the way
TEAM AGR: Actual Garage Racing. GMR has nothing.:PDT_002:
tyler7
injector question
Post by tyler7 »
bore what out, the fuel rail.
injector question
Lawl
