welll the lasted a whole five days! im at a lose. why would that fix it for a few days then go bad and the car go back to the way it was? it's bogging/missing/fauling out again. and i do not know what to do!
help!!!!!!!!!!!
Main relay? maybe? no?
all connections good and secure? ground to engine and chassis good?
J8k'S CRX
yes there all ok good and snug.GUNMETAL SI;61313 wrote:all connections good and secure? ground to engine and chassis good?
:stick:
J8k'S CRX
dizzy wnet bad again. the inner point wiggles around realy bad.
REFERBISHED CRAP!:PDT_Armataz_01_33:
:stick:
thats why i asked were the connections tite
ive experinced that before
tommygun89hb
i had the same prob i know it sounds funny but check fuse 14 no shit but just change it with a new one and then see if it fixes it if not laugh in my face but it might save you a lot of hassel
Mines doing the same thing, found out its my fuel pump though, checked the fuel pressure by hooking up a gauge and it bounces between 6ppsi to the stock 36ppsi, stomped it runs out and drops off to 26ppsi.
Maybe your having the same problem as me, but mine runs almost perfect till warm then spits about 3000rpm's to 4000rpm's then comes alive and drops back off.
Also found myself having to give more gas just to take off and it spits for a second then runs out fine till 3k till about 4k then rolls back onto its face and stomped till about 7300rpm's its spits then pulls out into redline.
I think you have a 255 walbro pump though don't you?
Also this is just a suggestion to see if you might be having the same problem.
J8k'S CRX
it turns out i put a bad dizzy in. am now replacinng it again, so will se if that fixes it, but if not ill check "fuse 14" as well as fuel pump.
:stick:
