anyone in stl build a high compression sohc vtec car?
i'm about to buy some d16a1 pistons but i'm concerned about how much is too much compression for the street? according to the comp calcs my build should be in the 12.14:1 area.
been reading alot on other boards but figured i'd ask around local first.
high compression
stlsupra
high compression
Bill H.
90 civic Si
not many stock parts left
90 civic Si
thsmrtone1
high compression
i had 10.5:1 srp's in my z6/y8 motor and with the head and the block both milled and the big cam i had the compression was around there or even a bit more. Daily drove it on pump gas.
SweetEBPSi
high compression
10.5:1 Isn't that bad. Mine has 10.1:1 stock, GSR has 10.5:1 (I think),and the ITRs have a 11.1:1. I think you could pull off the 12.14 but tune it really well. I'm not sure but if not tuned well and the high compression, I think your more prone to detonation. Not sure about that. Someone correct me if I'm wrong.N2HIFI;55526 wrote:i had 10.5:1 srp's in my z6/y8 motor and with the head and the block both milled and the big cam i had the compression was around there or even a bit more. Daily drove it on pump gas.
sharpie
high compression
my car is 11.6:1 and i daily drove it while i had it (in the body shop) didnt have any problems but since your that hight you might have trouble finding gas for it probally have to run nothing less than 93 octane which i can only find at some bp and like 2 qt's
high compression
Ummm QT only has 91, BP, Shell, Phillips66, Conoco, and most others have 93. SO its not hard tp find just gotta pay the extra for it.sharpie;55534 wrote:my car is 11.6:1 and i daily drove it while i had it (in the body shop) didnt have any problems but since your that hight you might have trouble finding gas for it probally have to run nothing less than 93 octane which i can only find at some bp and like 2 qt's
twkdcd595
high compression
e85 is pump gas and would handle 12:1 without a problem... would make some great power too.
high compression
Is this the corn fuel or something like that? I think a gas station in alton has it IIRC.twkdcd595;55536 wrote:e85 is pump gas and would handle 12:1 without a problem... would make some great power too.
twkdcd595
high compression
correct this would be a corn based ethanol (grain alcohol) fuel mixed with standard gas. 85% ethanol to 15% gas in the summer is standard, in winter some places bump it to 70-30 mix to keep the engine temps up in normal operating range (alcohol runs dramatically cooler, in cold weather this can cause some issues with getting to operating temps.).soundqjr;55537 wrote:Is this the corn fuel or something like that? I think a gas station in alton has it IIRC.
in MO and IL... there is a TON of stations that have e85. oh and to add it has an octane rating of 105. for some interesting information check out the wiki on it. http://en.wikipedia.org/wiki/E85
high compression
I'm basically reassembling this motor with a bigger cam LOL. The compression ratio of it was 12.3:1. I'll be bumping it down to 12.1:1 due to the different head design. I'll have to run 93 at all times and it will not be able to be driven without very good tuning.N2HIFI;55526 wrote:i had 10.5:1 srp's in my z6/y8 motor and with the head and the block both milled and the big cam i had the compression was around there or even a bit more. Daily drove it on pump gas.
