Wideband comparision
ok i was over on honda-tech and found a link to this article where the did a shootout/comparison of the most popular widebands available.
http://www.fordmuscle.com/archives/2007 ... /index.php
thsmrtone1
Post by thsmrtone1 »
wow, thats actually quite a surprise to me... ive never had a problem with my plx, but apparently the one they tested wasnt too accurate... i wonder if theres a difference between the m300 they tested and the sm-afr that i have, cuz +-1AFR is a LOT of variance...
I miss my honda ;(
b18b-t
Post by b18b-t »
i have a uego and despite its bad rep it still works well and very accuratly.
LowePerf
Post by LowePerf »
On the dyno my old PLX m-250 was about + 1 A/f off. I tried different sensors, checked supply voltages, checked grounds, nothing helped. It was no big deal as I knew this and tuned accordingly. I also checked it against my 5 gas weekly to be sure of any changes.
My 5 gas analyzer is an "emission quality" analyzer ($8000) that is calibrated with certified gas and does not just use oxygen to determine A/F but uses a Lambda formula using all 4 gases to accurately calculate A/F. This is why I use it as my "standard".
My experience with widebands are that no 2 can be expected to show exactly the same everytime. I just purchased a new PLX SM-AFR and it works perfectly. It's dead on with the 5 gas and I've ran it side-by-side with a F.A.S.T. unit also. The FAST unit reads about .1 leaner than the others.
While your wideband is a great tuning tool, it is just 1 tool. Sometimes you need more than 1 tool to get the job done. If your wideband reads 12:1 but everything else tells you it's lean, don't be afraid to pull plugs, check the EGT or anything else that you could do to confirm the A/F. I think when it comes down to it that ultimately we are responsible for checking our own equipment to make sure it right.
-John
Post by mike93hatch »
my m300 is dead on. if youre comparing it to a wideband sniffer on a dyno then that is not good. i have not seen one sniffer that was dead on. they were always off by +- 1 afr
LowePerf
Post by LowePerf »
I was not comparing to a dyno wideband, I was referring to my dyno wideband. This is the wideband that I use and logged with the dyno data. These comparisons are done with the o2 mounted in the pipe not in a sniffer pipe at the tailpipe.
You are about right though, if using an o2 mounted in a sniffer at the tailpipe add about .5 on the lean side. If the same setup is on a vehicle with a cat add about .5 more.
For you guys that say your wideband is accurate, I'm curious as to what are you referencing it against?
-John
thsmrtone1
LowePerf;52462 wrote:For you guys that say your wideband is accurate, I'm curious as to what are you referencing it against?
-John
not referencing it to anything, but it gives me a good starting point to get my fuel maps close before tuning the ignition timing... and gives me a reason to freak out when there is the possibility of detonation... like i said, ive never had a problem tuning my fuel maps with my plx, but i have no clue if it is as accurate as it should be.... and i definitely check my plugs to make sure.
I miss my honda ;(
b18b-t
Post by b18b-t »
LowePerf;52192 wrote:On the dyno my old PLX m-250 was about + 1 A/f off. I tried different sensors, checked supply voltages, checked grounds, nothing helped. It was no big deal as I knew this and tuned accordingly. I also checked it against my 5 gas weekly to be sure of any changes.
-John
very nicely put! as far as the uego being accurate, i compared the data with the plx. about +-1afr. Lowe do you tune shareware like crome? I was wanting to dyno tune my car as its only been street tuned a few times
LowePerf
Post by LowePerf »
b18b-t;52655 wrote:very nicely put! as far as the uego being accurate, i compared the data with the plx. about +-1afr. Lowe do you tune shareware like crome? I was wanting to dyno tune my car as its only been street tuned a few times
Yes, we do.
618-463-0224
twkdcd595
Post by twkdcd595 »
thought this would be a useful link to a thread on honda-tech about widebands I started.
obviously the best wideband on the market is the motec, but for people who are not going to spend over a grand on a wideband I started a poll to see what everyone has the best results with.
http://www.honda-tech.com/zerothread/2096374
and here is a link to that test being discussed on honda-tech as well... in which most people voice their opinions about that shootout.
http://www.honda-tech.com/zerothread?id=2027063
