Throttle not showing up on VAFC
Ok so my Vafc isnt reading any throttle response. I dont know if its a big deal or not but I was just wondering what would cause this. Like where it would say how much your on the throttle and it would give out a %. No matter if I floor ir or not it wont read anything. Thanks for your help.
AJ
Check the input for the throttle wire at the ECU and check to make sure your TPS is plugged in. If both of those are good, check the codes on your ECU and see if the TPS code comes up.
SilverStreak;51601 wrote:Check the input for the throttle wire at the ECU and check to make sure your TPS is plugged in. If both of those are good, check the codes on your ECU and see if the TPS code comes up.
Ok will do tomorrow man, I may need help but ill try to look up how to do it tomorrow. Also if my tps wasnt hooked up could that make me idle high?
soundqjr;51602 wrote:Ok will do tomorrow man, I may need help but ill try to look up how to do it tomorrow. Also if my tps wasnt hooked up could that make me idle high?
I think it could do that. If you want, come over to my house tomorrow tomorrow and we can have a look at it.
yes and no are you haveing any throttle related issues?, mu TPS sensor on the EF is bad and i do not have a throttle signal at my vafc either but my ecu does not need a tps signal to allow the car to run right (because its chipped)
N2HIFI;51607 wrote:yes and no are you haveing any throttle related issues?, mu TPS sensor on the EF is bad and i do not have a throttle signal at my vafc either but my ecu does not need a tps signal to allow the car to run right (because its chipped)
Well see it idles around 3,000 but I thought that due to no throttle bracket. But I havent had a chance to go to the boneyard yet and find one. So I guess yes its having issues.
aj when it high idles , if you put your foot under the gas pedal and pull up does it idle back down to normal? also have you checked your intake manifold bolts to make sure they are tight , thats the peoblem alex had after the ls/vtec swap
N2HIFI;51611 wrote:aj when it high idles , if you put your foot under the gas pedal and pull up does it idle back down to normal? also have you checked your intake manifold bolts to make sure they are tight , thats the peoblem alex had after the ls/vtec swap
Nope stays high. Ill check the bolts tomorrow.
Post by 90CivicEx »
Spray around the intake manifold with some Starting fluid that will tell ya if your intake gasket isn't compressed and it's breathing past. I've done it a few times swapping manifolds and makes for a quick way to find out something.
andyjt
Post by andyjt »
soundqjr;51618 wrote:Nope stays high. Ill check the bolts tomorrow.
Nah, im pretty sure they are tight, in sequence, i remembered after allexs car and double checked them
-andrew
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
