cams?
sharpie
cams?
Post by sharpie »
thinking about getting some cams and was wondering what you guys/girls were using on the street i have a b18c and want an agressive cam like skunk2 stage 2 or crower stage2 and 3/4 i would also like to know how hard it was to start/drive in winter/cold weather
cams?
Post by Clayton »
it might help people to tell you what numbers you are shooting for
cams?
Post by rickles8099 »
also if youre na or turboed. whats done to your valvetrain, do you have any port work done, oversized valves, etc.
cams?
i think he has a head with full valve train, so if he is re using the head or the valvetrain then almost any cam will work. but if your using a stock valvetrain then you will be limited by what cam you can run
cams?
Post by Clayton »
N2HIFI;50559 wrote:i think he has a head with full valve train, so if he is re using the head or the valvetrain then almost any cam will work. but if your using a stock valvetrain then you will be limited by what cam you can run
god i hope he has some sort of valvetrain
please dont ban me
but if he is using after market valve train like i think chris meant to say he should of just upgraded everything all at once, too much of a hassle in my opinon to go to that trouble and not replace the cams.
sharpie
cams?
Post by sharpie »
guess i should have been more specific i just wanted to see what cams you guys were using and the kind of results you got right now i dont have any valvetrain or any valve work done im waiting to see what cams i get befor i get the valvetrain so i get one i know can handle them and chris i know the head your talking about could handle it but i dont want to use that one
sharpie
cams?
Post by sharpie »
o and its an na set up
99RedCivic
cams?
Post by 99RedCivic »
some of the more aggressive cams require some tuning so keep that in mind also.
-Lucas
sharpie
cams?
Post by sharpie »
99RedCivic;50610 wrote:some of the more aggressive cams require some tuning so keep that in mind also.
i know but i got to get the motor built befor i do that
Digital Sol
cams?
Post by Digital Sol »
sharpie;50611 wrote:i know but i got to get the motor built befor i do that
your going to want to have it tuned after any cam change......
i wouldnt worry about cams until your motor is built sense you still dont know what your overall compression is going to be to begin with' nor do we know how serious of a build your going into'.....too many unknown factors....build it, then choose cams based on your build
if your keeping the head stock than skunk2 stage 1's would be ok', there not too far off from the itr cams
personally if your simply wanting to upgrade the valvetrain and then some cams for the time being id search on h-t for cam's and there are tons and tons of dynos and comparisons between different cams and different set-ups'
