Turbo car bucks.
dclduke
Turbo car bucks.
Post by dclduke »
When my d16z6 turbo was running and I would take it past 6500 rpm it would buck, like it ran out of fuel or maxed out the turbo. It only did it in 4th or 5th gear. I was running a td04h(don't know which one) at 7psi, and stock fuel system with 310cc injectors. I also had a greddy blue box(i know, crap) which is all I could afford at the time.
I have just spent a crap load of money to get it going again(almost have everything, except fuel management) and I don't want this to happen again. Also, what is the difference between the chipping kits that xenocron offers?
Now I will have bigger injectors, fuel pump, and soon proper engine management. A friends capri turbo would do the same thing but nothing bad ever happened to his car. Can anyone tell me what the problem might be? Thanks in advance.
Dustin
deetz;48552 wrote:its all good, 90% of us on here are below average downstairs,so we try to make up for it by building fast cars that dont last more then a week
DC_T
Turbo car bucks.
Post by DC_T »
when i first turboed my integra ls it did something kind of like this. I was running dsm 450s w/ Emanage and it hesitated at around 5500. I ended up swapping out the dsms for rc 370 and re-tuned and it took care of the problem. don't know if this has anything to do with yours, it was just my experience.
Turbo car bucks.
sounds like a fuel pressure issue, what are you running at under load?
Turbo car bucks.
Well, I would use bigger injectors then 310's. If your staying budget, get the DSM 450's. And don't use the E-Manage again, its crap. Personally, I recommmend Hondata for your EMS. I think the features(sp?) and ease of tunability in the St. Louis area is great for the midwest.
Turbo car bucks.
Post by budget_crx »
adjustable fuel pressure regulator + gauge
dclduke
Turbo car bucks.
Post by dclduke »
With the blue box it just dumped fuel whenever it saw boost. Don't know how though.
Turbo car bucks.
Post by 90CivicEx »
If it the system was dumping large amounts of fuel and wasn't seeing high enough boost to make things equal out then it was fuel spikeing. Was there a semi harsh smell of gas under a heavy load or anything?
I also agree with Rob's method.
dclduke
Turbo car bucks.
Post by dclduke »
No gas smell. And I would think that at high rpm too much gas would just get burned or passed through(Basically the problem would be at low rpm).
And I will be using 440cc injectors, bigger pump, and fpr. Ditching the Greddy crap and getting it tuned!
