valve cover
91b16Adx
valve cover
Post by 91b16Adx »
this is getting really frustrating. i did my headgasket and didnt do the timing right. so now i cant get the valve cover back off. this inner 4 nuts came off easy as did the outer one with the ground attached to it. the other outer three will not come off. i think the nut is stuck to the end of the bolt. tis happened once before but the valve cover still came off. now the 3 are holding it down and i cant get it off. what can i do?help!!
valve cover
Post by 90CivicEx »
??? take a picture of this cause I'm sorta understanding what your saying but not to the fullest. Other then that spray a little penitrating oil on them and let it sit for a bit and hopefully the will come loose but sounds to me like you over torqued the vc bolts, there only suppose to be lightly tightened
91b16Adx
valve cover
Post by 91b16Adx »
possibly overtq'd?but what can i do to fix it? the nut wont come off the top of the bolt(the 4 outer bolts of the VC, that go down into the head).
valve cover
The Fix (Part 1): Remove the nut. Its not impossible. Use a breaker bar if you have too.
The Fix (part 2): Replace the nut and stud if you break them taking them off.
P.S. Its righty tighty, lefty lossey.
