question about throttle body gaskets
Drowzysleeper
Post by Drowzysleeper »
do i have to use a gasket or can i just use a liquid gasket? any help would be good.
IM AN EPIC FAIL
Post by 90CivicEx »
Drowzysleeper;46309 wrote:do i have to use a gasket or can i just use a liquid gasket? any help would be good.
I've used the liquid gasket before but after torqueing you have to let it setup.
Your better off using the OEM or OE spec gasket.
1SloB8teen;46337 wrote:Your better off using the OEM or OE spec gasket.
truth, there are air paths in there that you could seal up with liquid gasket... just go to any parts store and order one, they are like $2.
Drowzysleeper
thanks guys probably go with the oe then
IM AN EPIC FAIL
