installed front skunk2 pro s 2 coilovers
went to instal the rears but the head of the 14mm on the lca decided to snap off. bought some oem lca bushings but need to press them out and in at work (stlhonda) tomorrow. then it will be finished.
slowly gathering parts for an ls/vtec built. Rod studs, greddy magnetic drain plug. I have b18 engine mounts from yonaka (hope they work for what i need them for). I have a b18 that is coming out of a teg at the end of may. So it's coming together.
