cel codes help
slammed98ex
cel codes help
Does anyone happen to know what code 13 is on the b18a1?
1990 Crx Si Ls swap racing seats header exhaust jdm gsr trans
cel codes help
thia is what it is on a obd1 and 2
13
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure)
defective circuit or unplugged / defective sensor
13
cel codes help
13 BARO - atmospheric pressure sensor
and i believe that is built into the ecu. so you will probably need a new ecu.
what it does is basically adjust the maps accordingly to your elevation...such as if you lived in colorado vs missouri. honda had to make one ecu work in all regions and conditions.
cel codes help
yup, my thoughts were correct.. its right here
