Brad Penn Racing Oil... ftw.
has much higher levels of zinc dithiophosphate (zddp) compared to just about any other oil... mobil, castrol, quaker state, redline, royal purple, etc.
what kind of oil do you use?
twkdcd595
SPoole
I was running the Castrol Syntec blend and when I took the engine apart it still looked brand new. There was no build up at all.
99 Cobra04 Mountaineer
Midori
Dap hatch: Stock motor so whatever Erik Le put in there when he changed the oil lol
When the B16 goes in ill be using a 10w-30 Honda brand oil, which is a mobile synthetic blend, changed every 2000 miles
-'11 Taffeta White CR-V
I'm pretty sure the stuff you get from most Honda dealers is Mobile conventional. Rebadged Mobil Clean 5000. I used to buy my oil from the dealer until Vincel started to be douchebags about it. For some strange reason STL Acura uses Castrol Synthetic Blend. I never have figured that one out.MidoriMiller;149722 wrote:Dap hatch: Stock motor so whatever Erik Le put in there when he changed the oil lol
quaker state peak peformance. weight? what ever i feel like running that oil change. altho i have 2 cases of 10-40 and 3 gallon jugs of 5-30 in the garage. filter walmart/fram/advance whatever i get teh cheapest
Devil Crx
I use peanut oil and a coffee filter.
*GMR* CRX Superleggera
Midori
well thats better imo lol id rather use a conventional oil that will protect better and wont last as long rather than a synthetic oil that is made to last a really long timeSilverStreak;149737 wrote:I'm pretty sure the stuff you get from most Honda dealers is Mobile conventional. Rebadged Mobil Clean 5000. I used to buy my oil from the dealer until Vincel started to be douchebags about it. For some strange reason STL Acura uses Castrol Synthetic Blend. I never have figured that one out.
InspiredCg3
full synthetic valvoline 5w30. i worked at many car shops in my opinion its the best oil out there because it clean more than any other oils.....
Club S2ki
Cars:
2000 dodge dakota SOLD
1998 Civc ex coupe SOLD
2000 S2000 WRECKED
1988 Audi 5000 Quattro T SOLD
95 Del Sol Si SOLD
'98 Accord Coupe DEP DD
04' S2000 Silverstone Metallic
:honda:
huh?InspiredCg3;150026 wrote:best oil out there because it clean more than any other oils.....
you guys do you know you cant tell shit just from looking at oil right? doesnt matter if it "looks" dirty or not. doesnt mean it is. or still not doing the job as if it were new.
the only way to tell anything about oil is send some off for a oil analysis.
bobistheoilguy.com goto the forums and check out all the oil analysis people have had done.
boosted hatch
5.5qt of 5w30 royal purple and fram oil filter is what i use
