what kind of oil do you use?
Digital Sol
5w30 full synthetic royal purple
5w30 Royal Purple for me
nothing wrong with fram. youre just one fo those people who believes everything they read on the internet.impreza_GC8;148290 wrote:Mobil 1 in both my cars, 10w30. I use a ToughGuard or whatever those blue filters are. I avoid Fram at all cost.
pennzoil platinum 10w30 here for over 2 years...and purolator or fram filter depending on which store im at.
ill be waiting for someone to say something about pennzoil PLATINUM so i can also tell that person that they believe everything they read on the internet.
Granted Fram makes most oil filters for Honda, the Fram filter you get from Autozone is not the same filter you get from the dealer (At least as far as 88-00 Civics are concerned). The gasket and overall exterior design and casing are different and are not what should be used on 88-00 Civics. The gasket on the Fram filters has been know to cause leaks. Theres even a thread about it on here where a member's S2000 caught fire due to an oil leak from the filter. I don't have anything bad to say about the filtration of Fram filters. People have said that they tend to fall apart after 3,000 or so miles, but thats never been proven to my knowledge. Because of the way Fram designs they're filter's gaskets is the reason why I stay away from anything they make in general. This is why I use the OEM S2000 oil filter. Its made by Filtech Inc. and uses the exact same gasket that the OEM Civic oil filter has. Its also bigger then the normal Civic filter, which helps with filtration and oil temps.mike93hatch;148388 wrote:nothing wrong with fram. youre just one fo those people who believes everything they read on the internet.
Just my two cents.
i ALWAYS use oem filters, 1. its convenient cause of working at the dealer, 2. they just seem to be made A LOT better than all of the other filters you buy. i have only seen one gasket actually stick on and they dont crush like a tin can when you put a filter wrench on them.
H0NDA-MAN
Mobil whatever & Fram filters. I roll cheap.
MGS4
truman001
castrol cheap and oem filter. the wifes crv goes to the dealer. I'm lazy...
tkarner03
used to rock royal purple. now i use castrol gtx high mileage w wicks oil filters.
eh2_Erik
yeah, filters with the rounded gaskets never stick as apposed to the ones with the flat gaskets.bildo16;148398 wrote:i ALWAYS use oem filters, 1. its convenient cause of working at the dealer, 2. they just seem to be made A LOT better than all of the other filters you buy. i have only seen one gasket actually stick on and they dont crush like a tin can when you put a filter wrench on them.
Integra:
Im running Valvoline MaxLife 5w-30 (which is a synthetic blend) with the Valvoline Filter. Filter is the same as an STP oil filter.
Civic:
Had Mobil 1 full Synthetic 5w-30 with the Mobil 1 filter.
Now s13_Erik
