Hmmmm nearly free B, should I!?!
Lotek
Post by Lotek »
alright. i have the ability to get a b20 for 300+the 75$ towing fee to get it out of the shop its at.
it has a bad headgasket and thats all that is known to be wrong with it. its at the shop because the gasket and tranny are toast.
with these damages what do i need to look for to see if its still good, and also, what kinda price should i be looking at? i know B swaps are expensive as hell, but what if i already have the motor? what all needs to be replaced inorder to get her to work?
i drive a d16y8 ek.
6363527779
:hippy:
andyjt
Post by andyjt »
Lotek;18617 wrote:alright. i have the ability to get a b20 for 300+the 75$ towing fee to get it out of the shop its at.
i drive a d16y8 ek.
I think password jdm is selling jdm b20 swaps for $549.
Not sure if you mean your payin 375 for it, or the $75 dollars shipping for it.
Just something to think about before you factor in headgaskets, machining, etc.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
99PreludeSh
Post by 99PreludeSh »
I know some one who boosted their b20 running about 15-17psi with stock internals. I heard its one of the strongest honda motors , so I say go for it!
andyjt
Post by andyjt »
99preludesh;18620 wrote:I know some one who boosted their b20 running about 15-17psi with stock internals. I heard its one of the strongest honda motors , so I say go for it!
actually its the weakest in stock form, it has siamese sleeves. They are also thinner than any of the other b-s.
:msntongue:
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
99PreludeSh
andyjt;18622 wrote:actually its the weakest in stock form, it has siamese sleeves. They are also thinner than any of the other b-s.
:msntongue:
I have know quite a few people boosting them on stock internals and not having any sort of problem...how is that?
Lotek
Post by Lotek »
then why do people quote b swaps as costing so damn much? is the b20 a blacksheep?
also i was talking about the cost of all the stuff sept the engine needed in the swap.
also ive seen a few halfassed comments about them not fitting well. is this so?
im trying to decide before i spend money on my y8.
6363527779
:hippy:
andyjt
Post by andyjt »
99preludesh;18624 wrote:I have know quite a few people boosting them on stock internals and not having any sort of problem...how is that?
The sleeves are thinner because of the 3mm larger bore, but the sleeves are still the same outer diameter.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
Mwprs37
Post by Mwprs37 »
save your money, boost your D.
-Derek-
1993 Prelude VTEC...Boosted coming this spring.
Imagex4
Lotek
Post by Lotek »
^fo rizeal?
Thats what i decided last time, but the idea of a cheap B stirred my nuts again.
6363527779
:hippy:
Mwprs37
Post by Mwprs37 »
If you have to replace the head gasket and the tranny is toast, I'd say its not worth it...
If you want help with your D talk to mike93hatch on here or www.midmosr.com (he runs it)...hes the D-series master around here as far as I'm concerned...
http://stlhondas.com/forums/showthread.php?t=341
-Derek-
Imagex4
