Running rich???
Dabeastwthn
Running rich???
Post by Dabeastwthn »
I took the Civic in for emissions and it failed because it was running way too rich. I also seem to be getting really crappy gas mileage (about 200 miles to a tank)! Someone told me that a fuel injector could be stuck wide open causing this, but I just wanted some suggestions, from some fellow Honda guys, on what I should do before I dig into it.
I'm fine with emissions since I'm just going to register it at my families Washigton Co. address. I just want to fix the problem beause of the mileage.
2000 Accord 5spd Coupe
Running rich???
Post by rickles8099 »
how old are the spark plugs and spark plug wires. if they are too old they might not be getting a good enough spark.
sharpie
Running rich???
Post by sharpie »
i have the same problem in my car and i replaced the injectors, plugs and wires and that didnt work
Running rich???
sharpie;17213 wrote:i have the same problem in my car and i replaced the injectors, plugs and wires and that didnt work
how about the o2 sensor? if they get clogged they cant read right. if its old, try replacing it.
Running rich???
rickles8099;17214 wrote:how about the o2 sensor? if they get clogged they cant read right. if its old, try replacing it.
Its a new O2 sensor.
On a side note, I've been having the same problem with gas milage :dunno:
JonDubya
Running rich???
Post by JonDubya »
I have an issue as well and it's related to some sensor wirirng issue going to the ECU. TPS can be a good place to start, are you throwing any DTCs?
1997 AIGSR.
Fucking eh cotton!
sharpie
Running rich???
Post by sharpie »
i replaced my o2 but tps is messed up so i guess it would be a good start then hugh
Running rich???
Post by 90CivicEx »
meh just do a good tune up, replace fuel filter, pcv, plugs, wires, cap, and rotor.
Take it to a place and get a fuel system test and clean, walmart does one and it's like $25 bucks but does good work on cleaning everything.
Running rich???
90CivicEx;17285 wrote:meh just do a good tune up, replace fuel filter, pcv, plugs, wires, cap, and rotor.
Done, done, done, done, done, done, and done. I did plugs, wires, cap and rotor about 6 months before I sold it and the PCV, fuel filter, and fuel system cleaner a month before I sold it.
Running rich???
Post by 90CivicEx »
Damn, well who knows. Borrow someones injectors and try that maybe ???
