You'll need an external coil to use that.99ebpSi;15937 wrote:I bet this is the answer http://cgi.ebay.com/ebaymotors/99-00-HO ... enameZWDVW
What do you think? There is no way it is suspension related being that it is RPM dependent and goes away above 6000 and was helped for a while by replacing my spark plugs and wires...
Most Odd Engine Problem..Need Help
but, a new cap and rotor could fix the problem. just an oem replacement one.SilverStreak02;15939 wrote:You'll need an external coil to use that.
99ebpSi
I think I will just pick up a new OEM one off ebay...Thanks guys. If anyone else can think of another possibility other than the cap & rotor let me know.
Thanks,
99ebpSi
Thanks,
99ebpSi
besides that, you can use a 97-01 prelude cap. its 15 bucks99ebpSi;15937 wrote:I bet this is the answer http://cgi.ebay.com/ebaymotors/99-00-HO ... enameZWDVW
Why not drive done to AutoZone and fix the problem in 15 minutes :dunno:99ebpSi;15984 wrote:I think I will just pick up a new OEM one off ebay...Thanks guys. If anyone else can think of another possibility other than the cap & rotor let me know.
Thanks,
99ebpSi
ludeboy
x2, go local... they are pretty cheap.Spork;15940 wrote:but, a new cap and rotor could fix the problem. just an oem replacement one.
