help me build my ls on a budget
Drowzysleeper
Post by Drowzysleeper »
im going to be building my ls for boost. right now the head is in a 100 pieces and the block is completely stripped. im going to be building on a budget. the block need some work and im wanting to get low compression pistions the lowest i have found have been right around 450 new. does anyone know where i can find some cheaper. i will probably need rods since my buddy threw one away along with the messed up piston. basically im looking for some good web sites that have low prices. any help would be great. thanks in advance.
shawn
IM AN EPIC FAIL
JesSi
Post by JesSi »
Drowzysleeper;12408 wrote:im going to be building my ls for boost. right now the head is in a 100 pieces and the block is completely stripped. im going to be building on a budget. the block need some work and im wanting to get low compression pistions the lowest i have found have been right around 450 new. does anyone know where i can find some cheaper. i will probably need rods since my buddy threw one away along with the messed up piston. basically im looking for some good web sites that have low prices. any help would be great. thanks in advance.
shawn
You can't be on a budget for boost.
Drowzysleeper
well im wanting to do it right, just want to get the best prices i can on the net. so far the build i got is mostly from tunerschoice.com and it is right at 2000 that is for the head and block basically rebuilt for boost. im just looking for better priced web sites. can you contribute?
IM AN EPIC FAIL
JesSi;12475 wrote:You can't be on a budget for boost.
False.
Silver Knight
Post by Silver Knight »
what is your budget?
DC5
Drowzysleeper
around 1600 is my budget for the build. i will boost it later.
IM AN EPIC FAIL
Post by 5thgen »
http://www.honda-tech.com/zerothread/785522
$749 FOR CP PISTONS AND EAGLE BIG-BOLT RODS
DC_T
Post by DC_T »
^ good deal....i got most my stuff from honda-tech when i did my build last summer, tough to beat some of their sponsors prices.
Drowzysleeper
sweet deal i saved 40.00, does anyone know of some good machine shops i need to get my block bored to 83mm. and might have to get my crank turned.
IM AN EPIC FAIL
Post by 5thgen »
Drowzysleeper;12984 wrote:sweet deal i saved 40.00, does anyone know of some good machine shops i need to get my block bored to 83mm. and might have to get my crank turned.
are the sleeves stock? I would bore it to 81.5mm max if you are going to turbo it.
