damn cooling
stlmadpanda
damn cooling
Post by stlmadpanda »
wow im upset. while i was at work i figured i would look at why i have no heat. well i removed the thermostat and it was stuck open. no big deal put a new one in and wow. still no heat but now my damn cooling fan doesn't kick on. i jumped the terminal and the fan kicks on. therefore the switch should be bad right? I put another switch in and turns out that one is bad also. so what is my luck that i have 2 bad switches. could it be anything else. i drove home turning my engine off and coasting a ways then starting it again. its really annoying. looking forward to any help. I don't really have the money for a switch right now because im buying jake's tranny.
Drowzysleeper wrote:
stlmadpanda wrote:of course she did
Drowzysleeper
damn cooling
Post by Drowzysleeper »
come dig around in my garage mike. if you find the thingy your looking for you can borrow it until i get my motor delima figured out
IM AN EPIC FAIL
stlmadpanda
damn cooling
right on. i cant drive there though. i'll over heat. and im suppose to get the tranny and ride with reid to the airport to pick josh up.
Drowzysleeper
damn cooling
well i guess you could ride with reid to the house of sin and help carry my pool table down stairs.
IM AN EPIC FAIL
stlmadpanda
damn cooling
installed a new radiator fan switch, the one on the thremostat and it still doesn't work. life sucks when the honda dont run. its going to be a long night.
stlmadpanda
damn cooling
well this officially bites, the fan switches checked out fine. all fuses are ok. I need help. dont know where to go from here.
damn cooling
You could try a coolant flush. That was my problem when my EG started to overheat. Then I would try a raditor or water pump.
stlmadpanda
damn cooling
i went through rough 1 1/2 gallons today at work. the problem is the fan isnt kicking on. and the water pump is pumping coolant. i am stumped. when i jump the terminal at the switch the fan turns on when i plug it back into the switch and get it hot nothing happens, the guage just goes up.
damn cooling
Post by stolle »
jump the switch and let the fan just run all the time, if it still overheats you have bigger problems than just a t-stat or switch...
Team NOCO Crew Member #2
stlmadpanda
damn cooling
yeah thats what i'll have to do but i hate rigging things like that.
