water/alcohol injection?
jason_guy_yeah
How would I adjust how much cc of 50/50 mix at 40psi with a 80 (ccs ??)nozle, per lbs of boost?
jason_guy_yeah
yeah, the alcohol helps increase torque and a complete burn while the water helps cool hot spots. In other words helps decrease/elimate detonation. :msnnerd:
deetz
never heard anything good come out of that setup, pm justinl off stlsr hes running it on his boosted honda, hes had it for years and still get it right
~chris~
-scca setup 99 grand am gt
-85 cj7
-85 cj7
jason_guy_yeah
while (assuming) he dynoed the car and tuned the ecu/ecm. Did he impliment the water/alcohol system? Doing after well make less power. But, I'll talk to him and get some info on his setup.
deetz
yea superdave tuned it, it made like 300whp, but when he sprays that shit it boggs his car downjason_guy_yeah;4703 wrote:while (assuming) he dynoed the car and tuned the ecu/ecm. Did he impliment the water/alcohol system? Doing after well make less power. But, I'll talk to him and get some info on his setup.
~chris~
-85 cj7
-85 cj7
jason_guy_yeah
what kind of nozzle is he using? What psi are the injectors at? How much cc is he injecting per lbs of boost(I'm trying to find out)? What is the a/f reading when he sprays? Usualy the added alcohol will richin the hell out of it. Does he have a control box (not sure what the correct terminoligy is)? Hope this helps http://en.wikipedia.org/wiki/Forced_induction
no, water injection is a failsafe for a poor setup and is usually only installed on systems that are thrown together without much thought put into them. If you have hotspots than you need to get your A/F ratio right, get it tuned so its not running so lean. besides the alcohol will do much more cooling than the water will...jason_guy_yeah;4700 wrote:yeah, the alcohol helps increase torque and a complete burn while the water helps cool hot spots. In other words helps decrease/elimate detonation. :msnnerd:
mike
are you goin to run it on your 700hp setup?
jason_guy_yeah
well with stock sleeves, I'm shootin for 450hp. bc, I got fired from my job, well sorta.
