Where are places to get factory fastening hardware for Civics?
Example: driver side kick panel by the hood pull, I need to get the hardware that attaches it to the bracket, tired of kicking it everytime it comes loose.
now granted, it may be as easy as a 10mm x 1" bolt, I haven't looked at it very close lol
plus, I need a few other miscellaneous clips and stuff for it.
Places to get factory "hardware" like screws, clips, etc.
BFE
You can always get bolts and such from hondaautomotiveparts.com or similar sites.
I like hondas fasteners compared to off the shelf from wherever local. Unless you can get serrated flanged bolts. Most bolts I see are just bolts....a lot of honda bolts incorporate washers, etc.
I will sometimes go to the junkyard and use a drill and pull a bunch of screws/bolts.
Yeah most bolts are nothing more than standard metric sizes. If you do need some I have bins of bolts you are more then welcome to raid for free.
The dealer is usually pretty cheap for nuts, bolts and clips like that and you don't have to worry about shipping charges.
BFE
awesome, thanks guys!
J8k'S CRX
crxfornow
majestic is the place to go, but you have to have a minimum of a 30 dollar order
Edison Carasio
I've personally just gone to the junk yard and raided what I could. A pocket full of bolts and nuts etc will cost you a buck. If you don't wanna do that, I use Majestic Honda's parts catalog to look up the part number for the piece I need and just take that to the dealer and it's normally a couple bucks.
