My CRX keeps backfiring...repeatedly. I have a d16y7 in it.
When I let off of the gas you can hear it backfire, it almost sounds like it's bubbling.
And when I accelerate, once I'm in 4th gear, my motor starts to become really jerky and starts to stutter.
What's wrong with it? Any ideas?
Backfiring
aGUNS
Backfiring
Also, no check engine lights.
But when I was driving today the light did come on. But when I started my car later in the day no light.
aGUNS
Backfiring
What would be the first step in trying to solve this?
Replacing the oxygen sensor?
fry
Backfiring
Plugs wires cap rotor make sureambershelton;253845 wrote:What would be the first step in trying to solve this?
The dizzy bolts are tight and the.dizzy didn't move and throw timing off
aGUNS
Backfiring
I just tightened the cap, it was rather loose. But other than that everything seemed fine.
The plugs are pretty new.
We'll see if tightening eveythig helped.
95_gsrfodo
Backfiring
pull up the carpet on the passenger side to see the ecu, see if its flashing any codes, check the rotor.
Dan The Man
Backfiring
Sounds like when i had bad wiring to my MAP sensor, but I had a CEL with that
team NOCO crew member #4
Currently Taking A Break From The Game
aGUNS
Backfiring
I checked the code and its saying my injectors. so ill be changing those out soon.
