abs problems
91beatuphatch
abs problems
Post by 91beatuphatch »
when driving my car the abs kicks in when i slow to 5 mph or speed up to 5 mph. it only does it at 5 mph. abs light was on until this problem started. also it will do even if you slow down with out the brakes to 5 mph. is it a sensor or what?
any comments?
bks
abs problems
Post by bks »
You can read the ABS codes a lot like you read your CEL codes. I suggest getting the codes figured out and go from there.
Anti-lock Brakes System (ABS)
11 - Wheel Sensor: RF (Open/Short to Body Ground/Short to Power)
12 - Wheel Sensor: RF (Electrical Noise/Intermittent Interruption)
13 - Wheel Sensor: LF (Open/Short to Body Ground/Short to Power)
14 - Wheel Sensor: LF (Electrical Noise/Intermittent Interruption)
15 - Wheel Sensor: RR (Open/Short to Body Ground/Short to Power)
16 - Wheel Sensor: RR (Electrical Noise/Intermittent Interruption)
17 - Wheel Sensor: LR (Open/Short to Body Ground/Short to Power)
18 - Wheel Sensor: LR (Electrical Noise/Intermittent Interruption)
21 - Pulser: RF
22 - Pulser: LF
23 - Pulser: RR
24 - Pulser: LR
31 - Solenoid: RF-In
32 - Solenoid: RF-Out
33 - Solenoid: LF-In
34 - Solenoid: LF-Out
35 - Solenoid: RR-In
36 - Solenoid: RR-Out
37 - Solenoid: LR-In
38 - Solenoid: LR-Out
41 - Wheel Lock: RF
42 - Wheel Lock: LF
43 - Wheel Lock: RR
44 - Wheel Lock: LR
51 - Motor Lock
52 - Motor Stuck OFF
53 - Motor Stuck ON
54 - Fail-safe Relay
61 - Ignition Voltage
62 - Ignition Voltage
71 - Different Diameter Tires
81 - Central Processing Unit (CPU)
http://www.spoonertuner.com/manuals
To clear the codes...
oooooooor...
remove the ABS!
91beatuphatch
abs problems
hay thanks alot.
nick03
abs problems
Post by nick03 »
i quick fix is make sure all abs rings r not cracked and all sensors are clean
