Shopping list for auto to manual swap
Post by stolle »
Edison Carasio;236502 wrote:What stuff is hydro that I don't need? The clutch master cylinder? I'm not the savviest when it comes to transmissions yet. Sorry :(
you only need to worry about civic/crx 88-91, 92+ is hydro.
Team NOCO Crew Member #2
Post by stolle »
Edison Carasio;236266 wrote:Shift linkage from 88-91 Civic 5 speed or CRX 5 speed Pedal assembly from 88-91 Civic/CRX manual trans
Clutch cable
88-91 ED 5 speed transmission
ED 5 speed gauge cluster
88-91 Civic/CRX manual trans mounts
Shift knob and shift boot
Flywheel, clutch and flywheel bolts
Ok I think that's everything now? Anyone else have any suggestions?
And thanks for all the help, Stolle.
fixed it for you, no need for master or slave cylinders its a cable clutch not hydro!
edit: get two clutch cables, use one as a spare, keep it in the car, coil it up in the spare tire.
