z6 swap
CRX91
z6 swap
Post by CRX91 »
i looked at rywire.com and found what i need so everything there will fix the wire problem for vtec and all that good stuff?
EndlssMystry
z6 swap
Post by EndlssMystry »
stolle;235558 wrote:would recommend you get a harness from rywire.
:15millionsign:
'02 AP1 <3
z6 swap
Post by stolle »
CRX91;235572 wrote:i looked at rywire.com and found what i need so everything there will fix the wire problem for vtec and all that good stuff?
it should, which adapter are you looking at getting?
Team NOCO Crew Member #2
CRX91
z6 swap
Post by CRX91 »
obd0 to obd1 for the d16z6 190 dollar one
z6 swap
Post by stolle »
CRX91;235643 wrote:obd0 to obd1 for the d16z6 190 dollar one
that should have everything you need and then some!
CRX91
z6 swap
Post by CRX91 »
cant wait to get my car going. its going to look good ebay sprayed and vc.
and hopeing there is no smoke
CRX91
z6 swap
Post by CRX91 »
i have one more question for you guys?
the motor harness i use the z6 harness and then every thing from the converion harness that i ordered will plug into the z6 and my harness that goes into the car?
z6 swap
CRX91;236506 wrote:i have one more question for you guys?
You already asked that question and it was already answered. You reuse your OBD0 engine harness. The kit from RyWire has the provisions needed to add to the harness.
z6 swap
Post by 90CivicEx »
The rywire harness is completely plug and play for vtec purge and noid, and 4 wire o2 and even comes with the harness to plug you obd-0 dist plugs to the new obd-1 dist useing your exsisting harness there is no cutting of wires or anything it's all plug and play and stupid proof along with the obd-0 to obd-1 jumper harness for you ecu there is absolutly no possible way you can fudge this up.
Hook your obd-0 harness to the d16z6 plug your rywire kit to the ecu and run the clips for vtec purge and noid and 4 wire o2 out hook those up then hook up your dist plugs and fire it up.
On a scale of 1 to 10 and 10 being the hardest it's a 1 my friend.
CRX91
z6 swap
Post by CRX91 »
ok yes i no i use my old crx mount but that does not work the mounting points on the motor are strait across from each other but on the bolt holes are at an angl
