z6 swap
CRX91
z6 swap
Post by CRX91 »
so i picked up a z6 last night and i have a few questions
ecu what is the pafered ecu to use with this motor?
what harness do i use? can i use my old one from my old d16a1?
how do i wire it all so the vtec works in the wire harness?
i belive it is obd1 so i have to buy the jumper harness from obdo to obd1 am i right on that?
z6 swap
P28 ECU. From a 1992-1995 Honda Civic EX/Si.
Reuse your engine harness. Add wiring for the VTEC Solenoid, VTEC Oil Pressure, and 4-Wire O2 sensor.
Buy an OBD0-OBD1 ECU conversion harness from RyWire. It will be self explanatory on how to wire in VTEC and the O2 sensor.
Right. See Above.
CRX91
z6 swap
Post by CRX91 »
i have 2 more questions i for got to post
will my flywheel and clutch work with the z6 i have a d16a1?
would someone be willing to do the wrining for me i can pay?
z6 swap
CRX91;235547 wrote: will my flywheel and clutch work with the z6 i have a d16a1?
You want to make sure that the clutch and flywheel match the transmission you're using. If you used the clutch and flywheel with the transmission you're going to use now, it'll work just fine.
CRX91
z6 swap
Post by CRX91 »
yea im useing my old trans. i called adrinalin to see if they had a covertion harness
they had one but i would need to use a neo i was guesing that is a vtec controler?
is that also a good way to go and how do u use something like that?
z6 swap
Post by stolle »
CRX91;235556 wrote:yea im useing my old trans. i called adrinalin to see if they had a covertion harness
anything but adrenaline, dont call or use them for anything, obd0-obd1 harness is pretty easy you just plug the harness in and the ecu, distributor, o2 sensor and run the wires you need, easy...
would recommend you get a harness from rywire.
Team NOCO Crew Member #2
z6 swap
Have you not read the enormous thread in the Product/Shop Reviews section about Adrenaline? Why would you waste your time with them? They just want you to spend your money with them on useless products. They thrive on kids like you that don't know this stuff. Again, JUST USE RYWIRE! If you're not going to take our advise, don't ask for it.
z6 swap
I am not the type of person to care if my shit is real or fake, cheap or expensive, but there are some things you just can skimp on. Lately i have batteling a bad obd0 - obd1 conversion with a no name conversion harness(not my car), and its just not worth it, i have run into cold solder joints, and other issues. Go with the RyWire it will save you huge headaches.
CRX91
z6 swap
Post by CRX91 »
ok the only reson i called them is i dont have a credit card to order stuff off line thats it
and i need your guys advice so i can learn this stuff i have not done before.
if someone is willing to order it for me i have money at home to pay for it
z6 swap
CRX91;235570 wrote:ok the only reson i called them is i dont have a credit card to order stuff off line thats it
It take 30 minutes to get a checking account and debit card at First Community Credit Union. You get your card right there on the spot. Go do work.
