1990 crx
CRX91
1990 crx
Post by CRX91 »
im doing a rear disk brake conversion on my hf.
i wanted to know if i could us the e brake cable when i do the swap.
Devil Crx
1990 crx
Post by Devil Crx »
you need the ebrake cable from the si/da that you are pulling the rear discs from. Your current ebake cables will not work.
*GMR* CRX Superleggera
crx08
1990 crx
Post by crx08 »
and a 40/40 prop valve you can pull off a DA with out ABS
stl-imports.com/forums
Devil Crx
1990 crx
Post by Devil Crx »
crx08;208312 wrote:and a 40/40 prop valve you can pull off a DA with out ABS
You don't NEED this. to complete the swap.
crx08
1990 crx
Post by crx08 »
Devil Crx;208404 wrote:You don't NEED this. to complete the swap.
I did it when I did rear disc :dunno:
Devil Crx
1990 crx
Post by Devil Crx »
Thats fine. I'm not saying you can't use it or you shouldn't. I'm just saying everything will still work without it.
crx08
1990 crx
Post by crx08 »
Yea. I looked around on Honda-tech and people were saying to use it. but I guess what ever way you want to go it would still work.
Devil Crx
1990 crx
Post by Devil Crx »
crx08;208413 wrote:Yea. I looked around on Honda-tech and people were saying to use it. but I guess what ever way you want to go it would still work.
They say alot of things on honda tech. I'm just saying your brakes will still work if you don't have a 40/40 prop valve readily available.
1990 crx
Post by rickles8099 »
jerren is correct. the brakes will still work without changing the prop valve. however, the brake bias will be off if you swap the brakes and not the prop valve.
CRX91
1990 crx
Post by CRX91 »
ok its on a 89 hf he got it of an si i drove his car and the fedal went far almost to the floor will that happen with out the prop valve and i looked at the rear brakes and it dont look like they are working. there was sufest rust on the disc cou
ld that be the prop valve
