KS OVER RIDE on p72
boosted92
KS OVER RIDE on p72
Post by boosted92 »
i need to know how to turn off the CE light its throwing a code 10 knock sensor code i tride grounding it out but it stays on and im not ready to re chip the ecu any ideas?? thanks
boosted92
KS OVER RIDE on p72
Post by boosted92 »
p.s its a 92 civic with b16/gsr
KS OVER RIDE on p72
The obvious solution is to plug in the knock sensor or replace it if it's bad or non-existent. Is the ECU chipped already?
KS OVER RIDE on p72
Post by Gunmetal Si »
laffffffffffffffffffffffffffffffff
KS OVER RIDE on p72
Post by mike93hatch »
its real easy with a couple parts from radioshack.. dont need a KS anyways.. theyre fucking junk and always breaking and really expensive and not worth replacing just follow this and it will work like a charm
http://www.honda-tech.com/showthread.php?t=1181854
btw, use two transducers
boosted92
KS OVER RIDE on p72
Post by boosted92 »
thanks guys:15millionsign:
mlr198769er
KS OVER RIDE on p72
Post by mlr198769er »
Do yourself a favor and dont jerry rig your car. Go to a junk yard a buy a knock sensor if you cant buy a new one. Most ppl say f*** them but in the end its a safety precaution for your motor especially if your piling alot of ppl in your car and running it like a bat outta hell
