Dying Main Relay Fuse
Jawsiiv
Post by Jawsiiv »
Help quickly
93 Civic Si
Main relay fuse keeps blowing. I have cleaned the thermostat housing several times. Fuse number 12 is the only one that keeps blowing. No other fuse is blown. HELP
Fear only comes when people are close to something...failure or success.
Trace the wires and find the short.
Jawsiiv
Post by Jawsiiv »
update, fuse 24 is now exploding as well which connects for the Main Relay. I will trace the wires....this is so fruity. Would it matter if I did took my Air Conditioner out?
Post by mike93hatch »
you need a multimeter
Post by Clayton »
Jawsiiv;191595 wrote:update, fuse 24 is now exploding as well which connects for the Main Relay. I will trace the wires....this is so fruity. Would it matter if I did took my Air Conditioner out?
how did you take it out? cutting wires and stuff?
Jawsiiv
Post by Jawsiiv »
I took it out clean. Figured out it was a couple of wires to my VSS that were touching metal....cleaned it up, and now she runs....on to the over heating problem.
