Speedometer Quit
Jawsiiv
Speedometer Quit
Is the Tach working? If No, the VSS is dead then. I do not know if it is the same for your car, but the EG has like a little needle/linkage that links with the trans. If the needle in the VSS gets damaged chipped you need a new one.
Fear only comes when people are close to something...failure or success.
Speedometer Quit
I believe the tachometer gets its signal from the distributor, not the VSS.Jawsiiv;121738 wrote:Is the Tach working? If No, the VSS is dead then. I do not know if it is the same for your car, but the EG has like a little needle/linkage that links with the trans. If the needle in the VSS gets damaged chipped you need a new one.
Speedometer Quit
This is correct a VSS has nothing to do with engine speed.SilverStreak;121747 wrote:I believe the tachometer gets its signal from the distributor, not the VSS.
Miggyp17
Speedometer Quit
how do i replace this?
been rollin with the tach for quit some time and im so clueless on what to do
Speedometer Quit
Check for corrosion on the wires going to the vss. Look at the metal pins, they are sometimes prone to corrosion. I had to replace a pin on mine.....my dads car has a pin corroding as well.
Miggyp17
Speedometer Quit
mine was completly snapped got a new one from a friends car installing in the morning as well as fixing rear motor mount bracket it decided to cracl tjrpigj the bolt
