March 20 Tech-o-Rama Tech-talks, sponsors, dyno, prizes!
GTI-Guy
Bumpity for a great way to hang out this Saturday
The Track Is Where It's At! Upcoming events at
hacstl.com/forums/showthread.php?t=62897
working dilegintly to finish the car so i can get a base cornerbalance done on the car yay
luvmyhondas
effing Saturday events! FTL
GTI-Guy
Good luck, those will be good numbers to have. Doing the same myself. I'll be there from start til about noonish, hope to run into you06sik20z3;225606 wrote:working dilegintly to finish the car so i can get a base cornerbalance done on the car yay
SweetEBPSi
Like I previously asked on the corner balancing. Do they adjust for better balance or just give you numbers to work with and does it cost to balance it?GTI-Guy;225629 wrote:Good luck, those will be good numbers to have. Doing the same myself. I'll be there from start til about noonish, hope to run into you
GTI-Guy
You roll up, get weighed, roll off. No cost. No adjustment service done, but some subject matter experts around for advice and lots of good referral sources. Up to you or a shop to work with coilover adjustments to try and even things out ,,, that can run an hour of time easy.SweetEBPSi;225637 wrote:Like I previously asked on the corner balancing. Do they adjust for better balance or just give you numbers to work with and does it cost to balance it?
MaSSaCrE
Didnt read everything but is there any awd dynos
should of never went
