Del Sol Rear Window compartment full of water?
Tyler
driving around, heard water, thought it might just be the gas tank since i could only hear it when the window was down and couldnt find any water anywhere. then took a turn a little quickly and a friend noticed water had splashed into the interior from there. how can i get that water out easily?
Im a loser
:L33T:
Im a loser
:L33T:
SlowOne.5
shop vac is the 1st thing to come to mind for me.
how bad are your gaskets?
Finds it funny you (all) check my profile multiple times a day. Get a life.
Tyler
the water is in the area that the rear window rolls down into, so idk how i would get a shop vac in there. only thing i can really think of is drilling a hole in the bottom and letting it drain out, but idk if thats such a good idea......SlowOne.5;107512 wrote:shop vac is the 1st thing to come to mind for me.
Im a loser
:L33T:
Im a loser
:L33T:
SlowOne.5
ah, mis-understood where you were speaking of. well wouldn't that panel come off? i mean it would have to. either from the inside, or the trunk area anyhow.
i'd check into replacing your gaskets, unless you just left the window down on accident...
Tyler
its been like this since i got it a week or 2 ago. so idk if he left it down or not. ill check the gaskets thoughSlowOne.5;107530 wrote:ah, mis-understood where you were speaking of. well wouldn't that panel come off? i mean it would have to. either from the inside, or the trunk area anyhow.
Im a loser
:L33T:
Im a loser
:L33T:
.:si:.
if you need the gaskets let me know. we can get the gasket and install all of that for you!!Tyler;107536 wrote:its been like this since i got it a week or 2 ago. so idk if he left it down or not. ill check the gaskets though
:vtec228: blake:vtec228:
00 CiViC Si
95 Integra LS
~-*Broadway Glass*-~
:evil1:3146384545:evil1:
All Your Autoglass Needs
PM me for a price on any glass
00 CiViC Si
95 Integra LS
granturismonut
There are 2 drains for the back window located under the rear storage bins behind the seat I going to guess that these both got pluged up somehow (leaves, debris) if you remove your storage bins you will see the 2 drains, 1 per side (looks almost like split loom) it maybe possible to pull the end off and use a piece of wire to clear the blockage, and when it starts to drain push the hose back in the drain hole to save the interior. I wouldn't pull the end off that goes into the window track but the end that goes into the chassis. I've taken pics and circled where the drain goes into the chassis in red. Hope this helps. since the rear compartment is 1 large area I would try and just undo the passenger side drain as it seems easier to get to.
You do not have the required permissions to view the files attached to this post.
04 Subaru WRX Sport Wagon
95 GMC Suburban (Honda hauler)
94 Del Sol vtec (some boost is better than no boost)
91 Chevy S-10 V-8 (toy, soon to be gone though)
87 Honda 250R (as close to a Type R as I will get)
Tyler
if i do, about how much would that run me?.:si:.;107538 wrote:if you need the gaskets let me know. we can get the gasket and install all of that for you!!
thanks a lot. im gonna try that today if i get the timegranturismonut;107554 wrote:There are 2 drains for the back window located under the rear storage bins behind the seat I going to guess that these both got pluged up somehow (leaves, debris) if you remove your storage bins you will see the 2 drains, 1 per side (looks almost like split loom) it maybe possible to pull the end off and use a piece of wire to clear the blockage, and when it starts to drain push the hose back in the drain hole to save the interior. I wouldn't pull the end off that goes into the window track but the end that goes into the chassis. I've taken pics and circled where the drain goes into the chassis in red. Hope this helps. since the rear compartment is 1 large area I would try and just undo the passenger side drain as it seems easier to get to.
Im a loser
:L33T:
Im a loser
:L33T:
granturismonut
any luck?
Tyler
havent actually had the time to do it. im in the middle of moving right now, so dont have any time to take the back out yetgranturismonut;109169 wrote:any luck?
Im a loser
:L33T:
Im a loser
:L33T:
