Sunroof not working???
miamida9
well i got the si knowing that the sunroof is inop. well i checked it out today and it seems that power is making it to the sunroof. the relay does make the clicking noise. the only problem i can think of is that the fuse is showing that no power is running through it. the fuse is good and is a 30amp. any light on this situation is appreciated, even a picture of the wiring schematic.
:flipa: im a modern day pirate, i come, i conquer, i leave....... next city please!!!!
well if it has power to the roof when you push the switch then it probley the motor is bad, because if it has power and ground then it should work
andyjt
Something must be wrong majorly with the wiring or your testing. If there is power at the motor, but not at the fuse. Unless i am missunderstanding what you are saying.N2HIFI;74344 wrote:well if it has power to the roof when you push the switch then it probley the motor is bad, because if it has power and ground then it should work
Must be the motor. As the motor runs through the swith.
When checking power/ ground at the motor. You can verify that the switch works properly as from the open/ close position the current flow will change in direction.
If you need a motor i have a few extras.
-andrew
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
miamida9
well i figured it out. the sunroof wouldn't work, nor the interior light or the intermittent wipers, so i figured OPTION fuse under the dash. sure enough it was that. the fuse wasn't even there!!!! thanks for the input guys.
