long story short im trying to remove the two 14mm allen key bolts on the rear of the block, one of the left of the oil filter and one on the right, intake manifold is removed and the driver side bolt has been removed but the pass side is being a royal pain in the ass, seems to keep wanting to strip and it wont seem to budge...tried hand tools and air tools...was going to try a larger bit later w/hammer and an extra set of hands to hold it snug in place
but i was thinking more than likely im going to need to have to weld a nut to the plug and then go from there...any-1 in the ballwin/reinke area have a welder and could spare some time this weekend?
ill buy ya food and beer :biggrin: or $$ if need be....need this damm thing off asap
any-1 have welder? ...removing bolts on block
Digital Sol
andyjt
putting a catch can in?
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
Digital Sol
yup, adding/changing a few things before tuningandyjt;50737 wrote:putting a catch can in?
any-1 know any shops/stores etc that would rent out a welder? i know for sure o-reillys dosnt rent them.....
just need to weld 1 nut on the cap and then it should come right off with a little effort
Digital Sol
bah, think i have it taken care of
BOOSTADDICT87
you still need a welder?????????
Digital Sol
thanks, but i ended up borrowing one from a friend, it worked out perfectly'
BOOSTADDICT87
good to hear
