teg drop spring on my civic...
greggles
You will probably need a new camber kit too because that's a pretty low drop.
im down 3 or so inches and I dont need a camber kit. I have heard and read sometimes you domt need a camber kit.greggles;38125 wrote:You will probably need a new camber kit too because that's a pretty low drop.
2coupes
CoupeCouncil Member #_8
95 EJ1 Milano Red
93 EJ2 Aztec Green Pearl
Coupe Council! We don't need no stinkin' hatches!
CCFL!
Coupe Council
EJ1OC
95 EJ1 Milano Red
CCFL!
Coupe Council
EJ1OC
JZO6ETR
+1 for good page!!
Bitch I Might Be!
irevto9k
no way can u get away with a 3 inch drop and no camber kit
F>B+K ALL DAY :respect:
I do :biggrin: come look at my car for proofRsx03S;40720 wrote:no way can u get away with a 3 inch drop and no camber kit
for once nice post
I do, my tires don't camber hardly at all. The teg drop springs will have a tad bit stiffer rateing, which you won't really have any body roll in autocross but they will also help in drag because your ass end won't give out as easy. Problem you will find later down the road is the struts will start to weaken and give out but you should get at least 5000 to 10000 miles before ya notice anything.Rsx03S;40720 wrote:no way can u get away with a 3 inch drop and no camber kit
If there 3" drop springs on a teg look at the weight rating on the integra and your car and that will give the difference of the drop.
2coupes
did you read the link?Rsx03S;40720 wrote:no way can u get away with a 3 inch drop and no camber kit
95 EJ1 Milano Red
CCFL!
Coupe Council
EJ1OC
95 EJ1 Milano Red
CCFL!
Coupe Council
EJ1OC
