Ebrake Help!
Ebrake Help!
Post by Phate »
Recently I put on a rear disc conversion on my new hf. However, the ebrake cables that came with it are way too long. What should i do?.
Thanks In Advance
Ebrake Help!
Post by 90CivicEx »
Phate;34702 wrote:Recently I put on a rear disc conversion on my new hf. However, the ebrake cables that came with it are way too long. What should i do?.
Thanks In Advance
hmmm, use your old cables from your drums. there the exact length and I know the end that connects to the ebrake has the right end but I'm not for sure on the end near the disc brakes
Ebrake Help!
Post by Phate »
How do I get them off?
Ebrake Help!
Post by 90CivicEx »
Phate;34710 wrote:How do I get them off?
there should just be a pin holding it on near the disc that you pop out, if I remember correctly
Ebrake Help!
Post by Phate »
90CivicEx;34712 wrote:there should just be a pin holding it on near the disc that you pop out, if I remember correctly
Nice, thanks for now, until I have a chance to do it.
Ebrake Help!
Post by Phate »
Well, I went to check it out, and there was a pin on the disc assemblies, however, the ones off the drum setup that came on the car didnt have the thing that the pin wouldve gone through, so I guess ima just order some for that year si model.
Ebrake Help!
Post by 90CivicEx »
Phate;34990 wrote:Well, I went to check it out, and there was a pin on the disc assemblies, however, the ones off the drum setup that came on the car didnt have the thing that the pin wouldve gone through, so I guess ima just order some for that year si model.
werd make sure its a 90 to 91 si model.
Ebrake Help!
Post by Phate »
90CivicEx;35048 wrote:werd make sure its a 90 to 91 si model.
Werd. Did, thanks. Should be here thurs.
Ebrake Help!
Post by Phate »
Okies - So I got the new ebrake cables. Now, what do i need to do to get the old ones off the disc assemblies? I messed with it for a few seconds to see that theres a lil clip and pin holding it in, but it seemed to be attached elsewhere. Will I have to take off the rotor to get to it? And who has a haynes manual for the 88-91 crx's? I cant friggen find it at parts stores!
Ebrake Help!
Post by 90CivicEx »
Phate;36303 wrote:Okies - So I got the new ebrake cables. Now, what do i need to do to get the old ones off the disc assemblies? I messed with it for a few seconds to see that theres a lil clip and pin holding it in, but it seemed to be attached elsewhere. Will I have to take off the rotor to get to it? And who has a haynes manual for the 88-91 crx's? I cant friggen find it at parts stores!
the pin is held in by a cotter pin all you do is pull it out and tap the pin up and it should release the cable.
