cable clutch! cris (n2hifi) read!
J8k'S CRX
Post by J8k'S CRX »
who can help me adjust my (ys1) cable clutch it engages to late i wont it to be right off the floor and it's almost near the top. right off the floor it grips amazingly (exedy stage II) and i can't get it back. i have messed with it for awhile now.
Cris if you can ill come over and you can look at it for me. other wise can some one else help out?
:stick:
JesSi
Post by JesSi »
Why don't you research how to do it yourself? And isn't it spelled "Chris"..? You should actually come out to the meets and gatherings more instead of just posting on here expecting someone to help you...
J8k'S CRX
Post by J8k'S CRX »
JesSi;33867 wrote:Why don't you research how to do it yourself? And isn't it spelled "Chris"..? You should actually come out to the meets and gatherings more instead of just posting on here expecting someone to help you...
did research it buddy! and i just can't make it work. and cris can be speeled eaither way just depends. and as far as meet, i have had some money issues that just got cleared up so i can drive again now (were ever i please) and i beleve i said i would help with the swap ya did but no reply (were is the love jesse?)
:stick:
Post by 90CivicEx »
Honestly the difficulty level for this project is below 1, my 5 month old son can adjust your clutch cable lol. Walk out grab the adjuster top and loosen it little by little till you get to what you want, you will get slight pedal play but nothing more then a quarter to half a inch at the top of the pedal.
If you have tried both adjustments on the petal and near the end of the cable, then you need to add or remove shims on your flywheel(i dont remember which way to go to move the clutch)
Post by 90CivicEx »
btlfedgolf;33924 wrote:If you have tried both adjustments on the petal and near the end of the cable, then you need to add or remove shims on your flywheel(i dont remember which way to go to move the clutch)
I think its add, and theres no pedal adjustment on the cable clutchs just at the tranny it's self
90CivicEx;33925 wrote:I think its add, and theres no pedal adjustment on the cable clutchs just at the tranny it's self
There is an adjustment up at the top of the petal on a 4th gen.
Post by 90CivicEx »
btlfedgolf;33931 wrote:There is an adjustment up at the top of the petal on a 4th gen.
Hmm never looked for one since I couldn't find one on my buddys integra
O RLY? i'll have to look into that...
Post by stolle »
cable goes through the firewall goes over the top of the end of the clutch pedal no adjustment. i have had the whole assembly out and theres nothing to adjust, it should adjust just like corey said above...
Team NOCO Crew Member #2
